Hi Bushyze....if you're running the Spica on 1.5(cupcake) [out of the box] then the bluetooth will only function with headphones. The new update to Android 2.1 will enable the file transfer by bluetooth. If you're in a hurry then scan the posts in the Spica section for the leaked 2.1 firmware (although it is buggy and the official firmware will be distributed in April TBA).
