Root Splash and Animation
Kiwasad
I have my phone rooted with Velocity 1.1. I've been trying for a few days to change my boot animation and splash but every time I try it doesn't change.
Is there something I'm doing wrong? I tried clearing the cache and stuff too.
Oh, well that should all be flashable... You should be able to change them from the scripts with no problems... Which animation and splash are you trying to flash? I can make a .zip that you can flash from recovery for you.
Make sure velocity toolkit is allowed in the superuser app. If your not gaining root access before trying to change things with the velocity script it wont work. When youre in terminal emulator make sure you type su then hit enter then type velocity. Hope this helps. Its late and im tired so i might have missed something or might be completely wrong here.
