Root [Sprint/Cricket] quick aokp question
droid51378
I see that an ota update is available and I downloaded it. How do I actually install it? Tried flashing it and got an error.
Should I try to DL again? I also tried the manual download but was having signal issues. Network said empty and could not send text.
Hm, that's weird. Try to download it again. Idk what's going on. Head over to the XDA thread and see if there was issues listed in the original post. The link is in the rom list sticky
Hi new here ,hope I'm post this in the right place!Tried to root my sprint galaxy s3 with CMW,it failed tried it couple of times now I have 6 pending downloads , my question is how do I clear the downloads?
Are the downloads from Samsung (system updates) or are they from the Google Play Store? And which rooting method did you use? Try this. It's very quick and works on all versions of Android.
Samsung Galaxy S III - QbKing77.com
Watch the video a couple of times and you won't have any questions.
ota o.s. updates will fail when youre running a custom recovery. come on musicjunkie... you know this man!!!
I know. He said he has 6 updates. I just wanted to know what they were. Never said to download them. If they were system updates (which only come one at a time by the way) he would have to accept it and hopefully it'll fail. If it were from Google play all he had to do was clear the notif bar.
