I want the ability to tether, but I need LTE and Jellybean.
Anyone have suggestions on a custom rom?
While I have the most recent update, I'm not thrilled with the battery life.
Stupid question, but is LTE built into all Sprint Rom's now?
Many of the Rom's from my EVO 4g days only had 3g.
Thanks-
The capability is there for all Touchwiz based roms and I believe most (if not all) CM/AOSP based roms for the Sprint S3. The switch between 3G and LTE is sorta wonky on some CM/AOSP roms, however.
Referring to the EVO 4G, that phone used 4G-Wimax which was a separate radio altogether (2500 frequency) unlike 4G-LTE which is on the 1900 frequency which is used for voice and data already. If the rom didn't come from US (example most Chinese roms that didn't have a CM base), it wouldn't include Wimax.
That makes a ton of sense. Thank you for the quick explanation.
:thumbup:![]()
I'm on Jellybean and the Trev Mod wifi tether. On MY phone the wifi tether is intermittent. It will just suddenly disconnect, then I have to reconnect it again..
Are there any JB/TW roms that run faster than others, or offer over-clockable kernals?
Just got my S3 from Sprint. I'm using Odexed Blue, with the Apex Launcher. Seems very nice. Has Wireless Tether built in. Uses stock kernel. It's built on the latest 4.1.1 release.
Just wondering, are you getting 4G in the Bay Area on your S3?
I'm wondering because my girlfriend gets 4G connection all day long on her Note 2 and I don't get any 4G signal on my Evo 4G LTE. I'm thinking of switching over to an S3, which the tech said has a stronger antenna as the Evo 4G LTE, but not the Note 2.
it went back up already
What does it mean that they are not the same? We both have LTE phones, not WiMAX, so any 4G signal should be LTE, right?
I'm not quite sure what you're referring too, but if your phone is 4G-LTE capable, then you're only going to get LTE.
The other poster might be referring to the antennas in the phones. They are both LTE capable but probably aren't trade by the same company meaning one could pick up signals stronger than the other.
I still lost as to what you originally were asking.
