Root [Sprint] If only there was a way to put 4G on a flashed note 2...
kingjay2012
Life would be alot better if was actually a method or somehow or way to put 4G on a flashed note 2.. 3G is alright but without see that 4G on a phone like this, it gets me depressed at times lbs :'( if only it was a way
Since the phone has a 4G LTE radio, if you're not getting 4G it's because your carrier isn't giving you a 4G signal where you are.
I have it flashed to boost, so I think its a lil more to having 4G lte radio... I heard it has to be programmed.
