Hello,
I'm new to the forums, and new to rooting in general. Spring Galaxy nexus - was on stock 4.2.1.
I followed the steps over at the rooting guide (sticky at top of the forum), and was able to root. I want to ensure that I did things correctly, and would like some help in confirming the next steps. Could you help review the following and tell me if I am on the right path?
Already done:
Assuming I have the nandroid backup done correctly (step 3 above), I would now like to flash a custom ROM - thinking of trying out CM10.1 most recent monthly first (cm-10.1-20130304-EXPERIMENTAL-toroplus-M2.zip)
(Ensure that phone is fully charged before proceeding with next steps)
Next Steps:
Am I overlooking something?
Question 1: I was reading a guide for the VZN Galaxy Nexus by The_chief (link from the jbsourcery site) explaining how 4.2 had changed file structure, and noticed a comment in there: There are four partitions you want to completely wipe: data (this is also called a factory reset: do NOT wipe internal memory under any circumstances! NO NO NO!), cache, Dalvik and system.
What does the caution about "do not wipe internal memory" mean (w.r.t. Galaxy Nexus?
Question 2: Currently, the TWRP backups (and the Titanium backups) are on my phone. (I did back these up to my PC as well as a precaution). When I wipe the cache, and install the new ROM, doesn't that wipe out my backups on the phone too?
Already done:
- Unlocked bootloader (that wiped my phone)
- Installed/flashed TWRP (touch) 2.4
- Performed backup from TWRP (compressed backup). Is this the same thing as performing nandroid backup? It created a TWRP folder on my device, and under 3 subfolders, it has 9 files (boot.emmc.win, data.ext4.win, recovery.emmc.win, system.ext4.win and their corresponding MD5 files, and a recovery.log - 874MB all combined)
- Flashed SuperSU, and once the phone was booted up, it auto-updated itself to current version.
- Installed Titanium backup, and backed up all user apps/data, and then backed up some of the system data (call logs, SMS/MMS etc). I'll probably back up all system data just as a precaution.
Next Steps:
- Download cm-10.1-20130304-EXPERIMENTAL-toroplus-M2.zip from CM download site. Also, download the current gapps (for 4.2.2 / CM10.1) )from goo. im/gapps
- Connect phone to computer using USB, and place the CM zip file (and gapps.zip) on phone, and then, using ES explorer, move the folder to root folder.
- Disconnect phone from computer, and connect phone to charger
- Boot to recovery, wipe dalvik cache, and cache (anything else?)
- Install (flash) the CM zip, and without exiting recovery, flash gapps zip
- Exit recovery, and boot (expect to wait up to 10-15 minutes). If after 15 minutes, phone is still stuck, pull battery, and start over at step 4
- Set up google account, and allow apps to install from market
- Use Titanium backups to restore app data for a few apps (lightflow, tasker, sms/mms, etc)
