Help Sprint Mobile Network issues (Initially in Mexico)
Hi, I have searched the forum for this same issue but have not found a fix, I just bought an Evo 3D and I can't connect to the 3g service. The phone just keeps saying Mobile Network turning on I have done a data and prl update and it has not fixed the problem. I was wondering if anyone else had the same problem and was able to fix it? Thanks
Is your phone fully updated (including the last two OTA updates?) - If so, how are you trying to connect the mobile network? (there is a known issue with using the widget after the last update).
Try using the quick settings in the pull down status bar - or go to settings/wireless and turn it on from there.
If that doesn't work, you might want to call up sprint tech support and get them to reprovision your phone.
Yes I did the OTA, the quick settings don't work at all since I'm in Mexico they can't reprovision my line I have to wait until sept 8 when I go back to the us.
true. plus do you have international roam on our account?
do you live in mexico or are you visiting? are you in a GSM area or CDMA area? have you contacted sprint to see if they can provide further assistance?
has the phone been able to use Sprints service at all? or did this issue just start happening.
as Marctronixx said, the area of Mex you are in makes a huge difference, as Mex has areas of CDMA OR GSM, or in some cases both. Mexico is very inconsistent in network tech. If you have one of Sprints international phone's (i.e. Photon) you'd pry be covered if you have the international plan, if not, hopefully your in part of Mex with a CDMA network (since you're using an EVO). Either way, I wouldnt want to see your bill after much international data use. To see the complications we're speaking of, select "Mexico" from this website and scroll down... http://internationalroaming.sprint.com/IntlCoverage/WelcomeRoaming.do
EDIT: I live in AZ and travel to Mex from time to time, I turn my phone off when I get within about 5 miles of the boarder to avoid any international roaming fees. lol I hear they can get outrageous when international.
as Marctronixx said, the area of Mex you are in makes a huge difference, as Mex has areas of CDMA, GSM, or in some cases both. Mexico is very inconsistent in network tech. If you have one of Sprints international phone's (i.e. Photon) you'd pry be covered if you have the international plan, if not, hopefully your in part of Mex with a CDMA network (since you're using an EVO). Either way, I wouldnt want to see your bill after much international data use. To see the complications we're speaking of, select "Mexico" from this website and scroll down... http://internationalroaming.sprint.com/IntlCoverage/WelcomeRoaming.do
Thanks everyone, It's not a Mexico problem I had the same problem in the U.S but it wasn't a big problem since in the US I am able to use 4g, Here in Mexico they only offer 3g so I can't use the internet. I was reading that many evo's have had the same problem so I was hoping someone had a fix, I would appreciate it if the title was changed back to the Original title since it's not a Mexico Problem.
I haven't heard of people not being able to get 3g coverage at all so I'm not sure what you're referring to there. Are you getting 1x? You can check your settings by going to ##3282#, Edit Mode, Enter MSL, Click EVDO, Make sure preferred mode is set to 'Automatic'. If that doesn't work you may just need to wait until you get back to the states.
Honestly with all your variables it's going to be tough to figure out if the fix above doesn't work.
well sir/ ma'am you are currently in mexico, so the thread title reflects the current status of the issue and where its occurring.
get back on US soil and we can update.. ;)
we can google and find out lots of stuff that could be wrong with the evo 3D.
can you respond to some questions i posted above?
plus..
are you rooted?
done a battery pull?
factory reset?
what has sprint said? can you confirm you are in a CDMA area?
do you have an international plan?
Yes to all your questions, Sprint just tried to reprogram the phone. Like I said I had this problem in the US as do many others, but it's OK I'd rather return my phone if people on here are just going to be changing my title. My other sprint phone does get 3G.
You seem more concerned about the title of your thread than solving your issue. Plus sprint doesn't run this site so deciding to return your phone for that reason seems a bit illogical. Can you please help me understand why you believe many people are having this problem? You'd think this forum, for the EVO 3D which is a sprint phone, would be full of threads about this issue if it was so prevalent.
Whoa! I think we're all honestly trying to help you. (I know I am.) It's just nearly impossible to diagnose anything when you're not on Sprints home network, and really unjust to the EVO to claim its flawed when you're trying to operate it in Mexico where cell coverage/tech is inconsistent and likely incompatible with the device.
thank you for your feedback.
if you have hard reset the phone and tried to use it in its factory state (not installing any apps, etc) then either the phone has a faulty radio (there is a thread on faulty radio and GPS started by Early Mon) or due to you not being in a proper CDMA area. we cant know about the latter until you are on US soil on a definite sprint network.
is your GPS working by chance?
and you said "yes" to all of my questions, so you are indeed rooted?
we are all here to help you. relax. ive not seen any huge numbers of people posting about this issue either, and this site is pretty well known. ive not also seen this posted on the sprint forums. sure some may have the issue but are those folks in mexico as well??
Yes to all your questions...
Sorry for the way I responded, after trying several roms the only one that e worked was Shooter_S_Sprint_WWE_2.08.651.2_Deodexed_Signed_(8.26.2011). The GPS was always working so I don't know if I have a faulty 3g radio or it was the software. Because the 3g was not working out of the box that's why I decided to root it and try several roms. But once again I am sorry in the way I responded.
I live in AZ near the Mexico border and have been having problems connecting to the internet/market/Amazon all day today. It took me dozens of tries, and over 4 hours to download 3 mp3s today.
Sprint operater said that there was a problem in my area and it would be fixed by morning.:rolleyes:
Well if that worked then it would seem that you may have flashed a newer updated rom but didn't have the updated radio thats why flashing the stock updated rom worked. So if you go back to any other custom rom now you should be good to go.
Make sure you data reset your phone too. ##3282#, enter your MSL, and go to "data profile" hit menu/restore. I had to do that too to get away from that crap PRL sprint pushed on us.
What is MSL?
I hope I didn't just ask a really stupid question.:o
