Yeah but if I unroot will the update OTA happen right away or do I need to force it or anything?Wow you need to unroot to get that update of 4.4. That's kitkat 4.4 .... The 4.2.2 is jb.so unroot update . problem you may not be able to root and may can
When you unroot and do a factory data wipe it should be soon after that the update would be downloaded . now if the root works you are good the only thing is you are at 4.2.2 . that ROM you are running would be old I would say get something new . but your biggest thing is if root is available for your device .
