[Sprint] [ROM][4.1.2] Strike X - Customize Life ~ 10/22/12 [DIRT]
frenchy714
Android Expert
I take NO credit for the following. This is NOT my work:
"Strike X was built from CM source and modified to revive the original Strike projects for the crespo4g and the supersonic. Original CM kernel is included but the ROM has been tested with (and recommended with) Trinity kernel available at DerKernel. Also added are custom options unique to this ROM only, as CM and Strike settings are allocated to their own place in the ROM I assure you, this is not just CyanogenMod."
Check out the XDA thread here.
Please DONATE if you like this Dev's work!!!
