[Sprint] [ROM]LiquidSmooth-JellyBean v2.0 RC3[09/28/12]
frenchy714
Android Expert
This is not my work and take no credit for the following:
y_uV1s5a6WfZCgqEu_3DeRaioy1bIZNmq6guv_63xMgBbIt3mTxE8Dw8m9uZyq2_ZJjLYIxiY8ZsTtFV-QJDAUm4I7aKjYgz9zZdnHWmuJkYU68_o1c
What is included?
Lots of customization features including but not limited to:
Lockscreen text color, layouts etc, 5-8 Options
Color & Alignment (Clock)
Custom Navbar Targets (Up to 7)
Custom Navbar Ring Targets (Up to 5)
Customizable Colors throughout the Rom
Liquid Launcher (Custom with extra options)
Liquid Splasher (New Liquid Settings)
Theme Chooser
Framework optimizations to enhance performance
Ultra Slim Size: Deodexed, Debloated, Zip-Aligned and Opti-png
Startup script control (sysctl, cron, zipalign etc)
Forced Tablet Mode with DPI Changer
Status Bar Mods - Battery, Clock, Provider Name Changer and more...
Toggles (Both AOKP/CM style)
Check out XDA thread here.
Please DONATE if you like this Dev's work!
Read the thread and there a couple of issues currently. If you guys want to flash the ROM, go into the ROM zip...META-INF\com\google\android\updater-script...open with Notepad or similar and change "toro" to "toroplus"
there are two "toro"s that you need to change, and both are at the very beginning of the text.
Second issue is that this ROM (for now) will not connect to Sprints network, so no data....It's pretty much the same issue the first test JB AOKP build experienced and should be an easy fix for the Dev's.
