D
Deleted User
Guest
All the methods for rooting I have run across are for 4.1, not 4.2.1. How do I go about rooting the latest version, 4.2.1?
So did you get it rooted? Man it's dead in here.
I would recommend using JB Sorcery. By far it is the best ROM I have used in years, ever since some old Sense 2 ROMs for the original Evo. It stable and has a good bit of customization.
What's different than stock? Good lord. Everything! Flash it!
Customize nav bar, battery icon, clock, notification pull down, more lock screen options than stock 4.2. You can basically customize anything. Just flash it and you'll see why we're raving.
Guess I'm not installing a custom ROM at the moment (since bluetooth was the biggest issue for me with stock)
