Root [Sprint] Rooting Note 2 On 4.3?
Also here is a video, it is from a Note III but should give you an example and I am sure it also works on the Note II
so I downloaded kingo and I am getting ready to root. My one question is what about knox? how will that effect me on installing roms and such? Thanks for all the help.
Kingo keeps telling me failed, 4.3 samsung...
Also tried CF-Auto and it said PASS but then i got... knox blocked.
either way, idk what to do from here, nothing i do can root around knox
I think Skip's new toolkit will root 4.3, I would check that first and see
after rooting, you can freeze knox with titanium backup. but look at the list, there is more than one knox file located on the phone. you can also search this forum for "knox remover" .zip file and delete it once and for all.
Also tried CF-Auto and it said PASS but then i got... knox blocked.knox
If Odin says: "PASS" then your phone is now rooted but KNOX won't let you benefit of your being root because it won't let you "touch" the system area. You need to disable KNOX first. After Odin says PASS you should have an app called SuperSU in the app drawer. Run SuperSU and it should asks you if you want to disable KNOX, click yes and you're done. If you don't have such an app go download it from Google Play.
