Root [Sprint] Rooting note2, Cyanogenmod 4.3.3
Ok, so I have a sprint L-900 model, running 4.3.3, trying to get Cyanogenmod11 (kitkat 4.4 version) running on here.
I tried Kingo, and it always fails saying its not compatible or something
I tried CF-root with Odin 3.09, and also 3.04 on the PDA tab but its tripped knox about 3 times, so I'm not worried about the warranty at this point.
Seriously, what am i supposed to do here? I have cyanogenmod11 on the SD card waiting to be flashed, but when i try download mode with CF-root something odd happens
The green android guy turns red with an eyepatch, and i get an error that says that SuperSU is trying to access a protected part unauthorized when my phone finally does load android. Am i missing something here?
If you are already rooted why are you trying Kingo ??
I'm confused. Knox is saying i'm NOT rooted and super SU isnt working, i dont think it worked properly, unless im misunderstanding then there's an extra step to disable knox? I cant even superuser to get rid of knox
