I started experiencing the same issue about six months ago. I hate to be the bearer of bad news, but at least in my case I've (unfortunately) concluded that it's a hardware problem. I've changed ROMs, reinstalled different versions of Gallery, tried third-party camera apps -- nothing helps.
FWIW, the only way I've found to get the camera going again is to shut down the phone, pull the battery, and let it sit for awhile. Usually a half-hour or so will be enough. When I put the battery back in and reboot, the camera will be working perfectly -- but only for a short time, at which point it starts failing again. And in 4.3, Android apparently tries to restart a crashed Gallery more often, because the "Gallery has stopped" messages appear much more frequently than they did in earlier versions. It became so irritating that I ended up disabling the Gallery app completely.
I'd love to hear of any possible fixes for the camera hardware, because I really miss being able to use it for pics, scanning barcodes/tags, etc. Otherwise, I'll probably have to wait until I replace the phone with something newer since this one is (naturally) now out of warranty.
