Hi, bought this SPH-L720 and after my regular unlock sources couldn't unlock it I decided to try for myself. Tried a procedure on Galaxys4root that supposedly unlocks it for non-US carriers and tried my Jamaican sim. it did remove the 'invalid sim' message, now all I see is a red 'x' at the network signal bar.
Current status: V4.4.2. Bld# L720VPUFNG2.
History of what I did... Rooted, Downgrade base band to MDC, still showed V4.4.2, followed the entire procedure and got to the state of no signal but with invalid sim gone. Next I did the edit for APN settings, still nothing. Not sure what I did after that but I took a break and when i came back in the evening it was saying "Firmware upgrade encountered an issue, please select recovery mode in Kies and try again". Try as I might, Kies wouldn't connect so I got a stock 4.4.2 here (thanx) and flashed it with Odin3 v1.85 and voila ! Back to square one ! 1.5 actually because I still get that red X beside the antenna sig. None of the network settings yield anything, GSM/UMTS etc. Phone is also unrooted now.
What I need: Help to get it unlock and fully operational, I'll root/upgrade as high as I can (learning) so any help appreciated.
Pls excuse the long post but I wanted to list all that was done.
Thanks in advance.
Thanks in advance.
