Okay,This update we all know will not install with CWM & Root.
So,This is a guide to help you get it installed.
1) Download the original backup here: http://androidforums.com/force-4g-lte-all-things-root/742117-working-stock-nandroid-backup.html
And follow the instructions.
2) Download the Stock Recovery from here : http://androidforums.com/force-4g-lte-all-things-root/743724-recovery-stock-recovery.html
Again,follow the instructions.
3) Check in the apps on the phone to see if SuperSU/Superuser are installed.If so go into the SuperSU/Superuser setting and unroot/temp unroot.
4) Install the Sprint Update(B13).
5) Reinstall Root,I used this one,It works after update:
http://androidforums.com/force-4g-lte-all-things-root/701909-osiris-guess-what-2-owe-osiris-5-each.html
Follow the instructions.
6) Reinstall CWM,I used this one:
http://androidforums.com/force-4g-lte-all-things-root/706469-cwm-based-touch-recovery.html
Follow the instructions in the thread.
7) Reinstall the ROM you want.
And your done.Just remember,Once you have installed the update,You CAN NOT reinstall a previous backup.As it will remove the update and revert back to B09.
Hope this guide helps.
