HeebieGeebie
As FuzzyBear9 did, I joined to give my solution to this problem. I experienced the exact same issues as FuzzyBear9 but it was fixed in a different way.
I experienced the following symptoms:
1) Battery status showed 100% charged prematurely.
2) On restart, the battery symbol appears with an exclamation mark and temp gauge.
3) MTP connected and media scanning/completed intermittent.
4) Connecting an unconnected cable to the usb port causes the MTP message on phone.
5) When connecting the phone to a PC, only charging, no USB or Kies sync.
6) Removing the battery, sim, SD card, and cleaning usb port did not resolve the problem.
I spoke to Samsung and they were aware of the problem, it apparently was a known fault with the specific version of Gingerbread '2.3.4'. I needed to update to a newer version of android, but i couldn't since the USB connection was not working. They told me to take it to my local samsung repair shop and they will update android to the latest version. This fixed the problem. It was free of charge covered by my warranty. I now have Ice Cream Sandwich 4.0.3.
They put the wrong one on though because I have the I9100P and they put ICS firmware for the I9100 on mine. So I have lost my NFC functionality. This doesn't matter though because I plan to root and change the firmware anyway.
Thanks,
Adam
Thanks,
Adam
