I just got an Epic about a week ago. I have some stability issues with it, and inconsistent internet connectivity.
When running different apps, it locks up every so often, and I have to soft reset. Qik Video locks it up every time.
The internet connectivity often goes away. I'll have 4 to 6 bars on 3G (I don't have 4G in my area), so I have a good signal, but apps will suddenly not have access to the internet. I have to soft reset to get it back.
Also, the data speed seems really slow a lot of the time. My previous phone was a Mogul (Windows Mobile), and the phone sucked, but the data speed was faster than this one often is.
Did I just get a bad unit? Or is this typical for the Epic? How does the stability compare to the Evo 4G?
I'm trying to decide if I should switch to the Evo (since I'm in my initial 30 days). I don't care about the hardware keyboard - I generally use the onscreen keyboard anyway (I'd be going for the Evo, not the Shift). I do play games on it quite often, but not many 3D games, so the 3D acceleration shouldn't be an issue.
I do plan to root my phone and hack it a bit, if that makes any difference in the decision.
