coreybacon
Hi all,
i have a Vodaphone Samsung Galaxy S2 I9100T, which i beleave is the same model as the AT&T version.
it is currently not rooted, but i will root it if i need to.
i am looking for a Stable ICS Rom for it. but i can't seem to find one.
can anyone tell me of a Stable ICS rom for my model, and if the is any bad bugs ect, which would stop me from being able to use it for day to day use??
and if i would need to root it to install it?
And i need it to work for the I9100T model.
Thanks heaps for any help you can give
Thanks Heaps Corey
Thanks Heaps Corey
