I finally saw someone else report this over at the Android Forum.
I thought it was just me. Basically, from Standby (Blank Screen) and pressing the power button to bring up the lock screen is hit or miss. Sometimes when I press the power button and my screen stays blank, but in low light situation, you can actually see very faintly that the screen is really on. If you swipe your thumb up to unlock the phone within about 10 seconds, the screen will come on eventually. If you tripple press the power button, it comes on immediately. This is a real problem for me when this happens on an incoming phone call, because you cannot hit the power button to bring the phone to live or you will send the call to voicemail. The same thing happens when on a call, the proximity sensor turns off the screen, and if I wait 8 to 10 seconds after pulling it away from my ear, the screen will com one eventually. I thought initially it was the proximity sensor screen shutoff program I had, so I removed it, then I thought it was my Screen Shutdown and lock program that I had, so I removed that also with no luck. What a PITA!
I noticed this happening right after the 2.3.4 update?
I also wanted to add that I am not rooted and using the stock 2.3.4 ROM.
I have tried many battery pulls and two factory resets have been attempted, during which time I tried to individually install my software to determine which one might be the culprit, but with no luck.
I have not yet called Sprint, as I have found them to be useless in the past.
