Starting Fresh
J
johankid
Guest
im thinking of starting of reverting my phone to stock, rooting and putting back the ROM I'm currently on (Bionix V 1.3.1). I understand that to revert to stock, you must odin your phone - is this correct? I ask this because after I rooted my phone when it was running stock 2.2, I made a backup via Rom Manager. Should I simply revert back to this?
Also, what is the best way to backup all my apps + data before I do an odin or restore to Stock 2.2?
Thank you guys for your time!
Is this before I odin my phone? or before I do a nandroid restore of my stock 2.2?
well you do it before both. the easiest way (for me) is to get back to stock by using odin. never done a nandroid restore before tho
So does odin wipe out your information (external and internal SD cards)? If so, what do you use to backup your data and restore? That's the one thing I'm not sure of.
it only wipes your apps. everything whats on your internal and external sd card stays where it is. so for example if you have some gameloft game and you had to download some additional data, after using odin the only thing you have to do is reinstall the app
