Help Startup Sound Trouble
apavolka
Recently I noticed that when I startup my phone it rings rather than says "droid" like it normally would. Is anyone experiencing this or does anyone know any fixes for this?
Settings > Sound > Notification ringtone
BTW, that startup "Droooooooid" is notifying you that your SD card is ready.
Are you on a ROM...some change things like that and you have to set them to what "you" like, not what the ROM developer liked when he/she built it.
Could have been the recent update then...or underwear gnomes.
Mine changed too, to the beatbox droid, I don't remember when, I changed it back and it stayed changed back.
Well thanks all for the input. I'll just try to change the notification sound to the droid sound considering I use different ringers for every app.
