Many thanks kayst, works a treat!Maybe Silent Boot will work for you? It works on the Incredible, most of the time.
https://play.google.com/store/apps/details?id=com.antweb.silentboot&hl=en
I guess the real question is, "Why are you turning off your device in the first place?" Hmm![]()
Sad to say doesn't work for me. Maybe there are other options for rooted users?Maybe Silent Boot will work for you? It works on the Incredible, most of the time.
To boot into recovery to;
Flash rom
Flash kernel
Flash theme
Flash mod
Wipe dalvik
Download mode
Trouble shoot...
Does this only turn off the startup / shutdown sounds? I don't want to turn off something else I'm not aware of.Settings > Sound > Volume > System ( move bar all the way to the left ) then tap OK.
Edit: this is stock & I'm on Verizon.
Rooted users can simply delete system/media/audio/ui/poweron.ogg with root explorer or estrongs in root mode
It would only stop the startup/shutdown sounds. If rooted just rename the poweron.ogg and shutdown.ogg, change the ogg to bak, this way if you want them back you still have them.
