status bar force close problem
soheel
My phone is taking the .......
The status bar keeps closing, when ever i restart my phone i get this message " "Sorry - the application 'Status Bar (process.com.android.systemui) has stopped unexpectedly. Please try again'.
And then I see the Force Close button, and it disappears
Hey there and welcome to android forums!
I'm sorry to hear about your troubles.
Would you happen to be a root user? If not, have you tried giving the phone a reset to see if that would fix the problem?
someone help with my problem pls!!!
Merged threads. :) And you say you've done a factory reset? I don't see what it could keep acting up like that. Is there anything you did or downloaded before this started? By the way, what device do you own?
Dont know what i did, maybe downloaded some apps from play store
phone its a dual sim phone, only had it for 3 months as i broke my s3
I meant if it was a Samsung, HTC, Motorola device and what brand it was. :) Unless there's apps that were downloaded that are on there than I'd say get rid of them, but you did a factory reset that does that and more.
