jbdan
Extreme Android User
I received and installed my Steinheil crystal screen protector yesterday and it was very easy and clean. The protector is cut just a tiny bit smaller than the screen size so there's some room for error in the application. I applied it in a steamy bathroom, and as such there was only one dust spot that was trapped under the screen. That was easily removed by using two pieces of scotch tape (one to lift the film, and the other to pull off the piece of dirt). One minor quibble is that it it's not laying completely flat around the optical button. I've cleaned it several times, but it still isn't completely flat (most easily seen in the full screen, screen off picture). The bubble has become less noticeable as time has gone by, and perhaps it will disappear completely in a few days.
The surface is smooth - slightly smoother than the original surface, but not significantly so, and there is absolutely no orange peel at all. The screen is absolutely crystal clear, however it does pick up finger prints and oil pretty easily.
Attached are a few pictures so you can see what it looks like with the screen turned on, dimmed, and off. The 'banding' visible on the screen on pictures isn't in the wallpaper, and isn't visible to the naked eye. It's some sort of picture artefact. Enjoy!
yay actual pics bravo!
