Root Step by step going to 340?
me 2 im just gonna wing some things and see what happens. its hard to get straight answers here so if i succeed ill help you out lolol
As soon as Fab has apex 1.3 out I will be going this route since I'm still on the OTA .15 (2.2) ver of software.....
SBF to .320 then run the system only SBF to .340. From they I will install the newest ApeX which fab said will support .340.
Doing it this way gives me a safety net because if I brick my phone I just follow the same procedure as above to go right back to .340. :)
Ouch, unless you have a clean back-up of the OTA on your phone (assuming that you are themed and have a ROM, or one or the other) you would have to SBF back to stock one way or the other.
There is a install zip of the .320 out there that you could use to get that far, that will give you all the new files except Madden and the name .340.
