lablackdiabla
Member
step by step on reflashing the rom..please somebody tell how to so I can reflash my #2. what do i do in rom manager? and after that what do i do?
is that the second option in Rom manager?Reboot into recovery and wipe cache and dalvik nd just flash again
question when I go into recovery mode the only option i have on advance is install from sd or internal or back and restore. it dosnt have a reflash option or flash option. what do i do there?
Not on rom manager , i mean the recovery flashed.to.the phone? I don't.trust rom manager
its just a paperweight lolquestion when I go into recovery mode the only option i have on advance is install from sd or internal or back and restore. it dosnt have a reflash option or flash option. what do i do there?
Just follow the exact same steps that are in the original post of your ROM. I would suggest that if you are having problems you may want to re download the ROM as well.step by step on reflashing the rom..please somebody tell how to so I can reflash my #2. what do i do in rom manager? and after that what do i do?
