RazzMaTazz
Android Expert
I'm pretty sure that this won't work for the Optimus T. You should check out THIS Optimus T forum.Does this work for the Optimus T.
I don't know. I'm pretty sure that it can be flashed to MetroPCS, but I don't know about Boost.Can the optimus be flashed for boost?
I love this guide
I didn't list all possible basebands. In my original post, I wrote, "It'll be something like, "LS670ZVD..." or "LS670MVD..." or "LS670ZVH...", etc. There's no meaningful difference between a "Z" and an "M" so, for example, as far as this guide is concerned, consider "MVD" to be "ZVD" and "MVH" to be "ZVH", etc..." You have "ZVJ"....I don't have any of the baseband versions you've listed. Mine comes up as LS670MVJ_6150.
Optiauto-sfx.exe doesn't work with ZVJ so you have to follow the instructions for ZVJ....I'm having a problem with the optiauto-sfx program. It always ends up saying that the "zerglings did not leave interesting stuff" which according to it means it failed? I've tried this about 5 times now and it still hasn't taken.
I tried the reset where you hold the home, volume, power botton down. That did nothing.
Does this have anything to do with rooting or flashing the phone? If not, I'd suggest that you post a new thread in the main Optimus S forum. The only thing that I can suggest is pulling the batter for a few minutes, pushing the power button, and reinstalling a known-good, fully-charged battery.I have a LG Optimus S phone. It will not come on. I have 3 fully charged batties. I have a car, home, and usb charger that I tried all 3. All 3 work with my other lg phone so I know it is not them. When I plug it into a charger, It flashes the LG light and the 4 buttons at the bottom will flash on and off. I tried the reset where you hold the home, volume, power botton down. That did nothing. Can someone please help.
Windows should see your phone via USB regardless of USB debugging being turned on or off. (I just tested mine both ways.) Without USB connectivity Optiauto-sfx.exe has no chance.i installed the drivers but but the phone is still not read by windows except if usb debugging is turned off. anything i can do??? Optiauto-sfx.exe just says waiting for device to be connected.... pls help and reply asap...
Razz,
Great post...I now have the confidence to attempt this.
I started with ZVJ, so I've downloaded the update.zip, and added it to the highest level of the SD card. I've done
I'm not sure what you're asking. Usually if opti-auto-sfx ends up saying "It's a GG man!" then it worked. Are you saying it didn't work? When you start in recovery mode, is it the stock Sprint/LG recovery?I went back to stock ZVD and when I run optiauto-sfx it finds my device but it seems most of the lines state that it is unable to chmod or data is read only or operations are not permitted.
[+] Rush did it ! It's a GG, man !
But your log does seem to indicated that optiauto-sfx can't write to your file system. If so, I'm not sure why. You could try launching optiauto-sfx from your top-level directory. Maybe that will help.
Hmmm... You've probably already done this, but maybe go into "Applications" settings and make sure "USB debugging" is turned on?
Can someone give me a link to find a Cm7 mod download with the ls670? I couldn't find it on the website for this device! Thank you!![]()
I need to downgrade VJ before I can do anything, but I can't seem to get the rooting to work. ... My phone says "USB connected" and "USB debugging connected", so I tried to run optiauto-sfx.exe, then when it finished I downloaded the Titanium Backup, but when I tried to run the Titanium Backup, it said my phone wasn't rooted. So I thnk the optiauto-sfx.exe failed because my computer isn't fully "seeing" my phone... Any ideas how to fix this?
