Help Steroids Bluetooth problems?
Tokenpoke
Android Expert
I just purchased a rocket fish stereo headset and encountered a couple problems so I'm making a thread for anyone else experiencing my issues.
1. My phone picked up but does not recognise the device. Solution, turn headset off and toggle Bt off and on. Turn headset to discover mode.
2. I did that but it still won't work! Solution, put phone on "always discoverable" and try again.
3. My music skips and halts. Solution, toggle bt off and on.
4.my buttons to change songs isn't working. Solution, not all media players support bt button presses. I recommend poweramp pro.
5. After i get a call my music does the skippy thing again. Solution, toggle by off and on.
Unfortunately going direct to voice dial doesnt work with most headsets because the call button has its own function, normally it disconnects the headset.
The only solution I have found for hands free dialing through bt is to put a home screen icon on the phone spaced away from others in a spot you can find without looking. Thats what I did.
I use swype, and it will come up with some hilarious word combinations sometimes.
