Root Stick mount with otg cable?
Modman
Is it possible to use stick mount to directly connect nook to external usb hd with otg cable?
Don't know and don't have a NC here to try it.
On the HP Touchpad, you had to have a powered hub (to power the stick) + the otg cable.
Do you have the parts or only going to buy if it works? :D
I think I paid $7 for a powered hub. :D
My take on OTG... if you can't just plug the device in and have it work, it's not worth it. I'm not interested in building a Rube Goldberg device to get it to work.
Is power needed for all devices or just things like a hard drive?
Can I connect a thumb drive directly, or will it need power?
