Still waiting for 2.1?
GMann
For those who don't want to do any leaks and aren't all technical with their devices like i am, there is an easy way to smooth up the transition speed of your Hero until the official 2.1 update releases.
**DISABLE PEEP**
If youre logged on to peep, log out of it (if you have it as a widget, remove it). Get into your settings > applications > clear data/cache and force stop it. Simple as that.
You will see an incease in transition speed and notice a sped up on the net.....a little quicker and smoother pinch to zoom also HA
try it out
what if you have never used peep, or opened it, or ever used its widget? heck, what if you dont even have a twitter account? that is me, and i still have the slowness. peep has never been touched, not even once, on my phone.
