Root Stitcher Radio not working
MG765
I use stitcher radio for listening to podcasts. However, it has problems and I'm wondering if it might be related to my ROM.
Often, it will suddenly stop playing a podcast and loop back to where I started the feed. It will stay stuck in this loop until I close it out and re-start it. Sometimes, when I complete a podcast, it will automatically loop back to the point where I started the stream and play that loop over and over until I close the app manually.
My other podcast players seem to work just fine... Dogcatcher.... Google Listen.
Rooted Optimus V
2.3.7
CM 7.2 Backside IHO 20120131
Rooted Optimus V
2.3.7
I had those exact issues when using the stock froyo. it's a shame... stitcher is pretty good otherwise. i'm using Listen in place of stitcher for the most part nowadays.
Well I guess I'm gonna have to uninstall it. Too bad. I liked the idea of 'stitching' together my favorite podcasts so they would play back to back but unless somebody has an idea of how to fix it, it will have to go.
DoggCatcher is really good by the way. It has a great search engine and you can enter a RSS feed URL manually. You can even get it to load a feed from your sd card.
Stitcher... gone...
... but I'm getting to like DoggCatcher even more. I have found where I can make playlists of my favorite feeds which basically gives me the same functionality of Stitcher. Very nice.
