I chose to do what i guess is the harder way but i have herd that the easy way is not the best way its kinda just up to you. Here is the link from android-police Updated (4/21/2011): [Exclusive] How To Root The HTC ThunderBolt And Unlock Its Bootloader | Android News, Reviews, Apps, Games, Phones, Tablets, Tips, Mods, Videos, Tutorials - Android Policeand they explain how to do it very well if you do it right it should only take about 30 min or so good luck!! If you have questions just ask they have a link where you can talk to the people that developed the guideI want to root my phone but keep stock, my main reason for root was to get the latest RUU and get rid of bloatware.
What is the best way, just follow the adb steps to root then using power user privileges remove bloatware?
, and install the software after you've compiled from source using makefile. Hunt down the dependence's... dont just let the system pull them for you. Install the SDK on a linux box and actually use the emulator...
I hear ya... and it's so true. the problem with the "Not so easy way..." is that it still doesn't actually teach anything.... other that how to cut and paste. If your really want to LEARN what the commands are doing as to in effect troubleshoot problems... then install Ubuntu 10.10 with compiz fusion, so it's at least fun.., and install the software after you've compiled from source using makefile. Hunt down the dependence's... dont just let the system pull them for you. Install the SDK on a linux box and actually use the emulator...
You want to learn... this is what you need to do. You wanna copy and paste..... well... I think you see where I'm going.
I have not experienced any of that when i rooted my phone!! Have you installed any rom or kernels yet? Also have you backed up your phone and made and nandroid?As per my previous post, I managed to root my phone but now I'm experiencing some unwanted behavior. Here are some of the problems I'm seeing, let me know if anyone has had this problem and perhaps a possible fix:
1) Phone is now always switching between 1x and 3G, I would never see these two before, I always have 4G.
2) Slacker will cause my phone to freeze
3) Phone will hang sometimes.
I'll add more comments if I experience anymore problems, this is my first morning with the root changes.
I had that problem with slacker before i rooted and also after i think it has something to do with slacker im not sure. Try to uninstall and reinstall slacker and see if that works. But with the signal going from 1X to 3G i have not herd of you might want to ask WormDoes he is one of the best guys on here to ask things like thatIn short, No, my main concern was to root, keep stock and remove bloatware. So far I've been only able to root, I haven't been able to remove bloatware. It isn't as easy as it was with my Samsung Fascinate, where I go into the data/app folder and move the .apk files into my SD Card.
To be fair, I've been having problems with Slacker radio which does on occasions cause reboots (after skipping a few songs), and i was listening to it while the freeze occurred.
Oh and what raido version do you have? To check it go to settings/about phone/software information/baseband versionAs per my previous post, I managed to root my phone but now I'm experiencing some unwanted behavior. Here are some of the problems I'm seeing, let me know if anyone has had this problem and perhaps a possible fix:
No that is an older one the new one is 1.16.00.0402w_1 you can get the new one from here [RADIO] The Obligatory Thunderbolt Radio Thread - xda-developers you have to install it throught HBOOT thoughBaseband version:
1.16.00.0223r
is that the latest out there?
I am running it now since yesterday and i have not had one reboot yet. I know that some people have been having this problem but i think its a case by case issue.Are you running this version? According to the "disclaimer" there has been reports of it causing the phone to reboot? Has anyone experienced issues like that?
