Root Stock Android Interface in VillainROM 12?
Karum
Hey guys, had a little search and couldn't find any solutions or ideas on this one, either that or I'm just blind and missed it lol.
So I have VillainROM 12 installed on my Hero and have been playing around with various themes from the standard Sense UI to things like dxtop.
I do want to try out the stock Android UI which I believe is accomplished by just going into Applications>Manage Applications>HTC Sense and selecting clear defaults thus setting it to stock Android.
Thing is that in my install of VillainROM 12 the "clear defaults" button is greyed out and unavailable to be pressed.
Is this an intentional thing in VR12 or am I maybe going to have to re-flash in order to achieve this?
Thanks in advance for any help/advice.
You know what I hadn't even heard of those but I've now checked out Launcher Pro and it seems to work quite well.
Thanks for the advice!
Yeah, V12 doesn't come with the stock 'Launcher' app, that's why it wouldn't let you switch.
Yeah Xyro I thought that might well be the case, just wasn't sure.
Been using Launcher Pro for a bit, liked it a lot so bought the Plus version which has been running brilliantly for me so far all day. Very pleased with it indeed.
Thanks for the posts guys, very much appreciated.
