Root Stock apn settings
BadAngel
Member
Anyone know where to find the stock APN settings or care to post up a screen shot of theirs, i know in AOSP roms they are in system/etc, however when I look at the mobster rom files I cannot locate the apns-conf.xml.
Any help would be greatly appreciated! thanks!
what carrier do you have? here's just a quick link with a bunch of apn's
---> http://forum.xda-developers.com/showthread.php?t=1070288
this one appears to be more complete.
---> http://www.bestyoucanget.com/cellularapn.htm
---> Cellular APN Settings- Best You Can Get
Thanks, but neither of those links had the correct data.
I'm looking for the stock virgin APNS for the evo v.
I'm currently trying to get MMS working on an AOSP JB rom, and I know that the apns are all messed up. Im trying to view the ones from a stock based rom that has MMS working, however HTC is great at being elusive and hiding stuff LOL... I found it but I think its signed weird, so I'm still working on trying to see exactly what HTC had so that maybe I can replicate it on JB and get it working...
by virgin you didnt mean virgin mobile did you? --> What are the Generic Virgin Mobile settings for MMS, WAP or Internet? - Help & Support - Virgin Mobile Australia
those apn's didnt work ?
I have not tried myself yet, however I noticed a similar thread had been started a while back and they didn't seem to come to any type of conclusion. This leads me to believe I will not be able to get it to work so easily. I will let you know when I actually try though.
Was it mine? Because the APN fix isn't that easy on AOSP... according to JMZ, it's smali code changes that need to be done. Believe me, I've tried :p
On Sense 3.0/3.5/3.6/4.0/4.1 ROMs though, the fix is easy. Do what's in the OP of my thread here. Even though the title of that thread says Sense 4/4.1, it works on (theoretically) any Sense based ROM. Tested and for sure works on 3.0/3.6/4/4.1.
