My internet home page is stuck on Jetblue's Snacks & Beverages page! I flew this week and used their Wifi at JFK, which I suspect is the root of this problem, but I can't seem to change it. In fact, in the Settings page it still lists my normal home page and if I click "Home," it'll take me there. But in reality, whenever I start up it's Snacks & Beverages, every time. Not that I'm not a fan of their Terra Blues potato chips or King Nut Fancy Nut Mix, but...
I've deleted the history, cache, etc., restarted, shut down, deleted the Jetblue wifi network listing, changed the homepage to something new (not my 'old' one I'm trying to get back)...nothing has worked. Any ideas are greatly appreciated. Thanks.
Thank you, PyroSporker! That worked!
Any one having issues with it shutting down for now reason? Can you set chrome as your default browser? I have the chrome widget for book marks but they open in the native browser. And if I want to open any link it goes to the native browser as well. Any help would be appreciated. Thanks.
Glad to help with an annoyance like that. Little things like that, though small, can eat away at you and be a big bother.
Just for clarities sake, which method worked? Did trying a new tab work or did you have to clear all the application data? Clearing all data would've worked no matter what.
Welcome to the forums![]()
I used the new tab method. I thought I'd previously cleared all the data through the application, but I guess that was a fail. Thanks again!
This is exactly why I am here today! My built in browser keeps closing at random times and I have to start over.
I downloaded Firefox. I found if you go to Settings, App Associations, Web URLS then pick the app you want as default.
I couldn't get in to check sons grades coz pop up blockers on. How do I turn it off. I looked under setting but couldn't find a setting for that.
Thanx
probably not the right place to put this but I thought I would try. is there anyway to go back to the old format for google image searchk? the new one is locking up on my phone and I don't like it.
