Help Stock DINC info needed
vgp
Sup fellas! If any of you guys who have stayed stock can post the info System info or a screen shot or something I would appreciate it!
I Rooted then updated and have now gone back stock, but my ADD wont let me rest until in know I back to "out of the box" settings. Thanks in advance!
You aren't gonna get a screenshot, since you can use any screenshot apps without root ;) If you followed the proper instructions, you would have wiped everything with a 2.1 image. Shortly after booting it, you should have gotten an OTA update, that had some minor fixes. If this happened, you are definitely back to stock.
I has hoping to get a screen shot through the longer method ( that program's naem slips my mind ) or someone just writing the info down for me
I did everything as directed and I didnt get an update at boot, but everything looks back to stock. Its runnging the 2.1update1 now.
Its the A.D.D. im telling ya, but it bothers me.
Here is what I have:
Firmware version
2.1-update1
Baseband version
1.00.03.04.06
Kernal version
2.6.29-cc1c2268
htc-kernal@and18-2#1
Build number
1.22.605.0 CL161493 release-keys
Software number
1.22.605.0
Browser version
WebKit 3.1
PRI Version
1.28_002
PRL Version
51920
ERI Version
5
JUST CONFIRM PLEASE...lol
That looks stock to me. Though I don't have a stock phone to compare to, I just did a quick search on the kernel & software version. Already knew the baseband was correct.
