Every time I've made the attempt, when I format my link2sd partition to EXT4, then rerun the "recreate mount script", it said format not supported or no SD card inserted.
here go over to this forum you will get some fast responces its the OP for the [APP] Link2SD... Read thru from the part im sending you then post your questions.. i asked alot of questions about how to do this i may have your answers there....
Its on that page for a reason read down then ask your question...
I can tell you that ext4 is kinda like in BETA its not working on all roms... Its better to just go with ext2 or ext3 there easier... Pretty much the problems are basic as in cannot mount, cannot write or read, that sort of thing so you'll know very quickly if you need to pick a different format.
