if i reflash note 3 stock firmware on odin will i lose my warranty
i dont want to root my note 3 i want to downgrade my firmware to
PDA N9005XXUBMI7 CSC N9005XSABMI1 MODEM N9005XXUBMI6dynomot i was scared i lose my warranty btw is there any were other then sammobile i can download stock firmware from sorry for my bad english
Your English is fine![]()
You can't downgrade. Only flash firmwares of the same version for your model.
For instance you can flash 4.2 to 4.3 but not back to 4.2 and neither can you flash 4.4.2 and go back to 4.3 or 4.2.
this is the firmware on my note 3
Model SM-N9005
Model name GALAXY Note 3 LTE
Country Australia
Version Android 4.3
Changelist 2019540
Build date: Wed, 30 Oct 2013 07:58:12 +0000
Product Code XSA
PDA N9005XXUDMJ7
CSC N9005XSADMJ2
MODEM N9005XXUDMJ7
and this is the firmware i want to downgrade to
Model SM-N9005
Country Australia
Version Android 4.3
Changelist 1628120
Build date: Wed, 11 Sep 2013 06:30:59 +0000
Product Code XSA
PDA N9005XXUBMI7
CSC N9005XSABMI1
MODEM N9005XXUBMI6
can i downgrade or no i can't
Yes it is the same version of Jelly Bean - 4.3 you can downgrade. It is slightly older but that won't make a difference it is still 4.3
