Root Stock firmware .zip?
David Dubz
So my phone is working again. Yay! But I have a problem... the activate app is gone.
Also, it's having lots of problems. Lots. No lockscreen, can't update, and can't connect by usb, even though it says usb debugging enabled.
However, wifi works. Is there a zip file I can flash in recovery that will return it to the stock firmware?
If you want, you can dial ##VIRGIN#
-Click on Edit
- For the MDN, replace what's there with 0000001234
-hit OK
-For MSID, replace 0000006789
-hit ok
-hit Done
-Phone will reboot
-you should have the activate option again
You can then reactivate your phone with th VM/Sprint Towers
VM had me do this after a tower went down in my area.
-Click on Edit
-hit OK
-hit ok
-hit Done
-Phone will reboot
I did that, and then the phone app just closes randomly. And now everytime I turn on wifi, the phone completely restarts. Weird, it was working before. Thanks for the tip, but my phone is just having so many problems. I'm going to have it looked at by someone.
I dont think you can fix this because i think the phone is missing some vital stuff to make the phone connect with the network. Pretty much the phone works but is useless....just my thought though
Why don't you guys attempt to root it then with Jcases firmware flash method? It's long and tricky. Tell me if your interested tho cuz there is a step in his method he forgot to include and ill tell you what it is.
hey man same things happening to me did you get it fixed???:(
Nope :/ sorry. What I did is just call Virgin Mobile and was completely honest. I just didn't mention the rooting. Just tell them you have no signal anywhere, and the lockscreen is gone and whatever other problems you're having. My new phone is supposed to be coming in today or tomorrow
