Root Stock Kernel?
I could use this also. I mistakenly deleted my backup that contained the stock kernel. Now only have a backup with the undervolt.
Good news. I found that I was actually smart enough to back it up separately on my HDD. So here you go...
Let me know if you have any trouble.
how do i apply the stock kernel back
How did you root your Inc? Did you use the Unrevoked method? If so just copy that zip to the root of your sd card, boot into recovery (Clockwork mod) select "install zip from sd card" then "chose zip from sd card" select the stock kernel. Once it's done, reboot. You should be all set!
However, I'm not sure if you can apply a kernel over a kernel, so just to be safe wait untill someone who knows posts and says so. I don't want to be responsible for a bricked phone.
Or if you made a nandroid backup before you installed a custom kernel, you could do that also.
i used unrevoked but when i try to install it still has the same kernel i had
Install the kernel bu putting it on your SD card. Boot into clockworkmod recovery and go to install zip. find it on the sd card, press yes that you want to install it, reboot your phone. Check your settings > Software information and check to see if it went back to default
when i do this it still has the hydra kernel loaded any way of getting the same kernel that came from the factory back because i have to send it back to verizion or i will dump it in water lol lol
