Root Stock launcher
MidshipAc
Can some one put up the stock launcher apk. I don't have any of the stock files. I prefer stick over xperia launcher
Download terminal emulator. Then run the following commands to install the stock launcher.
su
mount -o remount rw /system
cp /directory with the launcher.apk/ launcher2.apk /system/app/
cd /system/app
chmod 644 launcher2.apk && reboot.
the phone will reboot and the launcher should be ready for use
This is what happened. The launcher was downloaded on to sdcard/download folder
red ive tried that. it says ""changing permissions was not successful. please note some file systems do not allow permission changes."
the system is mounted as ro. You need to run the mount command first. You could also install the latest droidsmith update. In 0.3.10 the system partition is mounted rw
Explain more in more depth how to run the mount command and the whole ro system thing.
