Root Stock++ no data or wifi
just last night i came from joyos to stock++, and everything(data, wifi, google play) worked immediatly out of the box.
did you flash the 900oc kernel? if sso then reflash this CM72RC1-Beta1-KernelCWM-requisite0.zip
then reflash the stock++ rom and reboot. you dont need gapps or the oc kernel with stock++
No I used the 800 mhz kernal. Im not sure what the issue is. If I instll the kernal first then stock++ wont load but if I flash it after stock++ then it loads but I have no data or wifi
redownload everything from the stock++ thread, install the kernel first and then the rom
chances are you may have a bad download
