I'm s-off and i'm trying to flash the odex stock rom in order to activate my phone but every time i try to flash i get stuck in a bootloop. I did the same wipe procedure with 3 different recoveries and i'm still getting stuck in bootloops. Any help?
what hboot are you on?
1.04.2000
that should be fine... try to download the rom again...
Run the ruu
Its still doing the same thing. I found a nandroid backup i did before i started flashing roms. I'm trying that now
EDIT: The restore wont even work. I'm screwed at this point
May I ask how? ( I'm new to this )
its a long and dreadfull process but in you case, i guess its necessary.. you will lose s-off, get locked, and lose root...
http://androidforums.com/evo-v-4g-a...evo-v-4g-ruu-flashing-guide-unroot-guide.html
edit: EHokie beat me to it... props
Ok. Quick Question. Do I have to lock the bootloader before I flash the ruu?
yep follow all the steps as mentioned in the guide
Try this. http://db.tt/wyfeGRt9
Something I put together today. Just a PG86IMG update. It about Like running the Ruu but without losing root or anything.
If you want to see the thread its here http://androidforums.com/showthread.php?p=5221192
....I wish I didn't already do it.
Sorry! I wish I could have posted it up for you earlier!
Its ok. I managed to flash the ruu but it still says s-off in bootloader.
