Hello world. I rooted my admire. Didn't back it up/deleted the metroweb browser because I didn't know any better. Now I would like to take it back to it's factory settings. My main goal is to get the stock metroweb browser back. How do I go about this?
I had this EXACT same thing happen to me, and thanks to Locklady... I was able to fix it.THANK YOU FOR THE HELP!
Not all is well just yet. From following your instructions, the app itself is back on my drawer. However, when I was on RootExplorer, it wouldn't let me install the application fully and would say "Application not installed". When I actually run the browser, the web pages will not load up...
Thanks, I see the app, but even after following your tips, the pages still aren't loading when I use it...11. Turn it back on and you will fine MetroWeb in your applications again!
Thanks again to Locklady for all of her help!
I had that problem once...
try these trouble shooting tips: one of them worked for me, although idk which one..lol
***go to (menu/manage apps)
all tab
find Metro Web click it..
and see if it says "Uninstall Updates"
rather than just "Uninstall"
press "Uninstall Updates" (if its there).
it'll warn you that you will be using the stock application... agree and continue.
while your in there...clear cache and clear data
Have you tried the websites on Wifi or just on Metro?Thanks! When I did this, the browser would stop freezing, even at that, websites still aren't loading...
Ok so your Web works on Wifi? I think it is something with Metro then on your account maybe.All I use is wifi
Have you tried opening a ticket with them?
I am sorry, I am confused.My phone isn't even activated.
I turned my phone off, then on, and the metro mobi page loaded up, but when I tried to go to Google, it wouldn't load.
What do you mean by "my phone isn't even activated"?
