Help stock rom
mkhtfld76
Member
Can anyone help me with stock firmware files for the vitria? Stuck in a bootloop. Someone should make a back to stock update.zip for this phone.
I also need the complete odexed stock rom. I need to pull a few things out of it so hopefully I can do the B137 update and stop getting the annoying notifications. Any help would be greatly appreciated.
if you want to bypass the OTA you can always just go into the build.prop and replace every instance of B132 with B138(or anything higher than the OTA) then go into cache and delete the ota and reboot.
