Help stock rom?
I know SuperR has a deodexed version of the stock rom somewhere in the all things root forum, but I really suggest DSF. I know for a fact the WiFi works, but I can't say about anything else because I don't run service on the device, it's my spare ( meaning I don't have it connected to a phone plan so I get no data or calls). But I can tell you that it runs so beautifully on DSF that I'm not sure if I will switch to Jb when they finally get it working for this phone.
Edit: you know what just to be extra helpful:http://androidforums.com/force-4g-lte-all-things-root/839159-rom-force-stock-b13-deodexed-unmodified.html here's the link that I think will be most helpful. If it's not what you're looking for I'm sure it can be found in All Things Root
Maybe JimSmith80 will make a DSF on JB now that it's fully working! JB is much faster!
I do agree though, DSF is soooo much better than stock (as long as you are using boost).
Cheers,
-SB
