gothicnerd1033
I saw something somewhere about wifi tethering working in 4.2.2 ROMs. Alot of others couldnt get it to work. I ended up giving it a try to see if it worked using the stock tethering built into the ROM. Ended up taking a few minutes after connecting my computer to my phone, But its working. I am currently using it because my internet went out for whatever reason.
Using PACman.
Just figured Id share this. It seems you dont need any other tethering program. Just make sure your computer is set to dynamic IP and your good to go.
Edit: Just so you know.. I have NEVER paid the 15 dollars for tethering... So It isnt because of that.
Using PACman.
