Help Stop chasing it
PHP:
That's not a bit, that's a huge offset. I've never used lecturenotes but using the supplied stylus (you are using the supplied stylus aren't you?) I have no offset at all in any of the apps I have used.
Have you any friends this tablet? If so try your stylus with their Note and vice versa. Either something is broken or there are serious bugs in lecturenotes.
I use LectureNotes and don't have such a huge offset. That is terrible.
If you just bought the tablet, and can't find a solution in the next few days, I'd exchange it for a new one. If you have a bad digitizer or something, it will be potentially unfixable.
