stopped working
backdown
Was on my way to Florida yesterday and my phone was charging, and it just shut off. When i plugged it back in, it just flashed the notification light. Now it doesn't do anything now. What sucks is im in florida, and wont be going back till the 28th. Guess ill be phoneless till then..
Have you tried taking it to a sprint store to see if they can help you out?
side note: do you mean you left your phone at home on your way to florida or is it with you in florida?
Taking it to a sprint store here in daytona here in a bit.
I have removed the battery several times, and nothing. Its so bad that if i put it on the charger, the notification light doesn't even come on..
I had mine not want to turn on after I shut it down. I removed the battery and put it back and then it worked though.
Took it to a Sprint store here In daytona and I asked the guy to put In a hero battery. He insisted It didnt fit and finally he tried it and It powered right up. New battery is on its way
